Results 1 to 17 of 17
Thread: Widest English? Not Narrow....
    Jul 2009
    Salisbury
    12
    I am building a lightweight Hillclimb car and I thinking of using English as the basis of the axle.
    i can find lots of threads for narrowing the axle but none about how wide they can be built?
    i guess adding the semi floating kit will make a difference but is there any info about how much wider it will end up at?
    My car is arched with 8” slicks.
    cheers
    Nev
    Re: Widest English? Not Narrow....
    cant really help, except that you cant really build them wider without using longer half shafts.
    someone may correct me on this but i think the widest engine axles would be capri, either a 1300 mk3 or 4 cyl mk1
    Jun 2007
    porthmadog
    62
    16
    Yes Some capris had wide English axles - one here-
    https://www.ebay.co.uk/itm/Ford-Capr...AAAOSwh9de3STk
    2,659
    268
    Quote Originally Posted by ktb76p View Post
    That is an English Axle, but he has described it as an Atlas in his description.
    3,241
    Where ? Doesn't mention Atlas anywhere? Hope it has the half shafts with it as I don't imagine suitable shafts will be common these days?
    2,659
    268
    I must've misread it. I could've sworn he said it was an Atlas when I read the full description.
    52” Ford Capri Axle with half shafts, back plates and brake rod.
    And you can't have read it properly either as it Clearly says "Axle With Halftshafts"
    3,241
    Both equally dim then - you got me!
    2,659
    268
    3,641
    Why do you want to go wider? Could you not just play with wheel offsets and spacers? Would be tricky getting wider shafts, a fully floating hub kits widens by about 10mm
    Quote Originally Posted by Moonraker View Post
    cheers
    Nev
    The wider English halfshafts do start losing their strength the longer they are, probably not as important if you have a very lightweight car with a lowish torque engine. As earlier mentioned you are better doing it on the wheel offset.
    Jul 2009
    Salisbury
    12
    Ok, all good info.
    Looks like i will get a casing and build one up and then sort the wheels to give my the extra width via off set.
    Nev
    Feb 2011
    ireland
    1,019
    241
    nothing wrong with a 52 inch English axle and better job than spacers .
    3,641
    Except they’re mega rare, shafts are hard to come by etc, you can easily make up that width with wheel offset and hubcentric spacers
    Spanner Monkey Mkdu's Avatar
    Oct 2009
    417
    14
    you can start with a standard one and modifying it like these people :
    https://www.premiermotorsportdevelop...axle-258-c.asp
    they can do 57"
    Feb 2011
    ireland
    1,019
    241
    i have them and not be too dear if anyone wants
    Jun 2014
    leeds
    58
    127
    Stick to standard width and run 10" rears with wider slick, why bother with wider axle, more weight.
    Apr 2004
    Bangkok, Thailand, Thailand
    4,346
    479
    Plenty of options for wider stronger axles. If you want to go wider, go for a toyota pickup axle. Circa 1980. I can't remember the model number.
