Page 2 of 2 FirstFirst 1 2
Results 41 to 73 of 73
Thread: Pinto breathing and catch tank set up
  1. #41
    Pit Crew Craigorypeck's Avatar
    Nov 2009
    Edmonton Canada
    949
    96
    Re: Pinto breathing and catch tank set up
    Ah right... makes sense. will just stick with both being routed to catch tank for now.
    My crank case breather pipe is real messy inside prob best being routed to a tank, its just full of mayonnaisey crap, wouldn't really want that ending up on the tappets!!
  2. #42
    Spanner Monkey James-HPE's Avatar
    Oct 2007
    Tolworth
    245
    Forget that, get it cleaned out! It's no good having partially blocked breathers!!!
    Mk2 Escort 1700 X-flow-1/4 mile 12.76 @ 102mph «NUFF SED»
  3. #43
    Nov 2009
    Edmonton Canada
    949
    96
    Ha, indeed.. i learnt that the hard way! Half a sump blown out the rocker cover, what a mess.
  4. #44
    Spanner Monkey djdavyb's Avatar
    Jan 2009
    Chelmsford, Essex, United Kingdom
    397
    9
    im just about to start on my breather set up, i was going to run a line from the crank case to the side of the rocker cover, then use a take off on my filler cap straight to the catch tank. This was i should need to weld a defletor plate as the oil filler cap is at the highest point causing least risk of oil running straight to the catch tank. Sound about right? or am i in dream world?
    > > ESSEX RWD < <
    PS3: djdavyb
    add me!
  5. #45
    Oct 2007
    Tolworth
    245
    Should be fine as long as your breather in the cap is big enough! Dont forget, it's breathing for the crankcase aswell!
  6. #46
    Mechanic Turbosport Subscriber ebenech's Avatar
    May 2010
    Montevideo, Uruguay
    495
    61
    Hello Jason, scraper received today. It's a very neat and carefuly worked oil scraper, and I'm very happy with the pruchase I've made. Also it's very nice and easy to deal with you.
    Cheers,
    Eduardo
  7. The Following User Says Thank You to ebenech For This Useful Post:
  8. #47
    Ireland
    3,579
    173
    Re post:
    This is the first one I designed and made, now have the hole positions perfected, minimal if any filing to fit, will suit any rods with std 2.0 crank
    High quality item with two proper location points unlike all other scrapers
    Price for the scraper is £30 + £8 registered postage to UK and rest of world, sent with a piece of wood on one side to keep the plate nice and straight
    Have about 10 in stock at the moment if interested send me a pm with your address and I will send you my paypal email
    The scraper is fitted with RTV sealant on both sides of the scraper and a normal cork gasket on the other side, both sides will be level when fully tightened
    Fit the sump tighten the bolts, let the RTV sealant set over night, then fully tighten, will give a perfect seal
    The half round rubber sump seals need to be modified slightly on the scraper side, simple cut 1mm off the bottom with a razor blade so that the seal sits on top of the scraper
    Bulk discounts available
    I should also add we would expect a solid 2 to 3% increase in power using this vs std wet sump and no scraper, plus reduced air in oil and reduced oil out the breathers, it all helps
    Regards
    Jason
  9. The Following User Says Thank You to RWD fords rule For This Useful Post:
  10. #48
    Pit Crew 5tox's Avatar
    Jul 2012
    cambridgeshire
    1,054
    does the crank scraper require 2 gaskets (one either side) just curious really
  11. #49
    Ireland
    3,579
    173
    Hello, no the scraper does not require any gasket on the scraper side, you use a good quality RTV sealant each side of the scraper it seals 100%, then you use a normal cork gasket on the opposite side of the engine, instructions included with the item, sump hole positions now perfected, for sale here
  12. #50
    Oct 2007
    Tolworth
    245
    Hi Jason,
    We haven't had a chance to use the scraper yet, but we will do in the next a couple of months so I'll let you know my feedback!
    James
  13. #51
    Ireland
    3,579
    173
    Cheers James
  14. #52
    Jul 2012
    cambridgeshire
    1,054
    will watch this with interest, a crank scraper was not originally on my wish list for the pinto ill be putting together but looks an interesting concept
  15. #53
    Oct 2007
    Tolworth
    245
    It's one of those things that isn't going to set the world alight, but can only be better then not having it, and for the money that Jason is charging, you can't go wrong IMO
  16. The Following User Says Thank You to James-HPE For This Useful Post:
  17. #54
    Feb 2015
    Bristol
    58
    Hi, Just seen this old thread, when you run breather from the crankcase do you keep the pcv (valve) on the crankcase outlet? or do you remove it. Thanks.
  18. #55
    Jan 2009
    397
    9
    I done away with mine and replaced it with one of these....http://pages.ebay.com/link/?nav=item...d=151593420148
    > > ESSEX RWD < <
    PS3: djdavyb
    add me!
  19. #56
    Quote Originally Posted by MK1 WIDOW View Post
    you must remove it, either by using an elbow in teh link above, or just cut the very bottom of the pcv valve off so the guts fall out
  20. #57
    Aug 2017
    Lulea Sweden
    61
    Find this old thread, RWD fords rule do you still have Pinto crank scraper?
    Thanks for your help!
    Anders
  21. #58
    Apr 2013
    S Wales
    233
    433
    Same question here: Are these still available, Jason?
  22. #59
    Mechanic hawk1903's Avatar
    Jun 2009
    istanbul
    956
    269
    Quote Originally Posted by dt36 View Post
    Hello.
    Jason is not active in the forum much lately. I may have a spare one which I might be able to get a laser cut copy. However I am off to Nec show and can check within next week.
  23. #60
    Apr 2013
    S Wales
    233
    433
    Hi Hawk, thank you.
    Have tried to PM you, but i don't have enough posts yet.
    Definitely interested.
  24. #61
    May 2007
    Vic, Australia
    662
    133
    You can try jason via his email,
    rwdfords@hotmail.com
    or via here,
    http://www.mctengineering.com/contac...n-engineering/
    Shaun
  25. The Following User Says Thank You to escortinadriver For This Useful Post:
  26. #62
    Apr 2013
    S Wales
    233
    433
    Quote Originally Posted by escortinadriver View Post
    or via here,
    Shaun
    Thank you. Much appreciated.
  27. #63
    Jun 2009
    istanbul
    956
    269
    Hi Hawk, thank you.
    I can send you my spare set ( free of charge ) if you like but I don’t know if you are allowed to share your address here.
  28. The Following User Says Thank You to hawk1903 For This Useful Post:
  29. #64
    Apr 2013
    S Wales
    233
    433
    Quote Originally Posted by hawk1903 View Post
    Hi Hawk, can you try and send me a pm, please? Maybe I can reply through that. If not, then I just need to post a bit more to get my count up.
  30. #65
    Apr 2013
    S Wales
    233
    433
    How did you rate the Scraper when you fitted it?
  31. #66
    Mar 2012
    Shropshire
    407
    Also tried emailing him with joy
  32. #67
    Apr 2013
    S Wales
    233
    433
    Quote Originally Posted by theduck View Post
    I tried email on MCT site and rang both numbers. Unfortunately, no reply on either.
  33. #68
    Jun 2009
    istanbul
    956
    269
    PM sent
  34. The Following User Says Thank You to hawk1903 For This Useful Post:
  35. #69
    May 2007
    Vic, Australia
    662
    133
    Shame Jason isn't around much these days as his work was top notch.
    I have one of his scrapers in both my pinto and cossie bottom ends.
    The only other contact I have for him is rwdfords@eircom.net
    Good luck.
    Shaun.
  36. The Following User Says Thank You to escortinadriver For This Useful Post:
  37. #70
    Apr 2013
    S Wales
    233
    433
    Hawk, you absolute legend.
    Just got home from work and there was a package all the way from Turkey.
    Thank you again my friend.
  38. #71
    Jun 2009
    istanbul
    956
    269
    Pleasure helping you. I hope it fits and works well.
    Best regards
  39. The Following User Says Thank You to hawk1903 For This Useful Post:
  40. #72
    Apr 2013
    S Wales
    233
    433
    Best regards
    Fitted it yesterday. Needed a very slight trim on number 3 crank journal position.
  41. #73
    Mar 2003
    Now over the pond North side
    3,540
    Just bringing this back to the light of day
    Did anyone manage to contact Jason?
    Did the Harris boys start using the scraper? I wonder if they started to sell/use them in their builds?
    Might be dropping the sump off of my Pinto so thinking I could do this at the same time?
    Dazzle
