skip to about 6:05 for the assembly bit where it starts to make more sense, looked quite good imo, don't know why it wasn't used
Lots of friction??
but they're is almost an endless continuation of firing and seeing that it rotates (just like the rotary wankel) i bet its smooth.
Looks like a big AC compressor
my guess its it has no real torque, and i cant see all those roller bearings standing the test of time
Lots of friction with roller bearings too although they can last a long time we have pumps offshore that run at high rpms for years with rollers, if the alignment and lubrication is good they are fine, do porches not have roller bearing cranks?
Stolen from Wikipedia.
The Dyna-Cam engine originally came from a design by the Blazer brothers, who worked for Studebaker in 1916. They sold the rights to Karl Herrmann, Studebaker's head of engineering, who developed the concept over many years, eventually taking out US patent 2237989 in 1941.[11] It has 6 double-ended pistons working in 6 cylinders, and its 12 combustion chambers are fired every revolution of the drive shaft. The pistons drive a sine-shaped cam, as opposed to a swashplate or wobble-plate, hence its name.
In 1961, at the age of 80, Herrmann sold the rights to one of his employees, Edward Palmer, who set up the Dyna-Cam Engine Corp. along with son Dennis. Edward's son Dennis and daughter Pat then helped get the engine installed in a Piper Arrow. The engine was flown for about 700 hours in the Piper Arrow from 1987 through 1991. Their longest engine ran for nearly 4000 hours before overhaul. Dyna-Cam opened an R & D facility in around 1993 and won many various awards from NASA, US Navy, the US Marine Corps, California Energy Commission, Air Quality Management District, and Los Angeles Regional Technology Alliance for different variations of the same Dyna-Cam Engine. About 40 prototype engines were built by the Herrmann Group and another 25 built by the Dyna-Cam Group since they acquired the engine and opened their shop. A new patent was granted to Dennis Palmer and Edward Palmer first in 1985 and then several more around 2000 to Dennis Palmer. In 2003 the assets of the Dyna-Cam Engine Corp were acquired by first Aero-Marine Corp. who changed their name to Axial Vector Engine Corporation.[12] Axial Vector then totally re-designed the cam engine. Axial Vector's new engine, like many of the others on this list, suffers from the "put in everything" problem, including piezoelectric valves and ignition, ceramic cylinder liners with no piston rings, and a variety of other advanced features. It has almost no similarity to the original Herrmann and Dyna-Cam Engine since the Dyna-Cam Engine used conventional valves, piston rings, accessories, had no unproven ceramic materials and actually flew in a Piper Arrow and also powered a 20-foot (6.1 m) Eliminator Ski Boat for over four years.
Check out Stirling engines they are very cool
seems a good design but you have to wonder how long the bearings and little end rollers are going to last? but only revving at 2000 rpm max good question? seems a mix of design between a wankel and a rotating cylinder vailve (rcv) to me!
