Results 1 to 11 of 11
Thread: pinto turbo BIG power 561HP
    Jan 2011
    Norway
    This belongs to a frend of mine in Norway. This is the dyno video.
    http://www.youtube.com/watch?v=DFCuY...ature=youtu.be
    Spanner Monkey the1theycallthe1's Avatar
    Jul 2007
    The Midlands
    36
    305
    Re: pinto turbo BIG power 561HP
    Jesus - what's the spec? Any more pictures?
    Jan 2011
    Norway
    Setup is his little secret, all I know is
    STD crankshaft and stroke, KVS custom pistons and rods,
    camshaft with KVS custom design and 1.8 bar turbo pressure.
    sorry no pictures.
    Mar 2012
    2,118
    Not normal kind of power. Power to win.
    Power and torque curves look very strange. Seems like turbo pressure need some time to build up? Is this a drag-race engine?
    Jan 2006
    in my garage
    918
    62
    Kin ell,what is it going in??
    Trinidad West Indies
    172
    Respect to the guys behind that!!
    I too would like to know what its going in and what times it would pull if on the 1/4 mile....
    Regards,
    Kevin
    Jun 2003
    Teesside
    2,406
    That is some pinto
    Spanner Monkey Luke's Avatar
    Sep 2006
    Perth Western Australia
    392
    The friggin pinto still being developed, awesome
    May 2007
    Vic, Australia
    662
    133
    Huge dohc beating numbers. Definitely need some more details. Is it using a factory ford ohc head or aftermarket? Injection Setup? Good to see use of the EMS system. They're a great unit.
    Shaun
    Jan 2008
    Up the garage
    2,775
    218
    That is awesome to see!
    Scandinavians constantly come up with awesome power engines - what are they doing right and we are doing wrong!?
    Feb 2011
    Norway
    Hi Shaun.
    I dont wont to tell to much about inside the engine, but I can tell this:
    I have used a factory 2.0ohc 8 valve head, but there is many small things inside there making power.
    The intake manifold is homemade and with a 70mm throttle body, it is 1200cc injectors controlled by ems motorsport ecu.
    It is a base engine giving 200hp without pressure and we did not do the 561hp pull til power peak
    Max power is on 8500rpm and still full on 9000 rpm, but we did not try that on high pressure, so there is more to give.
    Best regards Knut V Sveinungard KVS
