Engine is a 2.0 pinto.
The carbs are spitting back from around 1000 rpm to 2500 rpm.
It ticks over just below 1000 nice and even, but if you feather the throttle then it will spit back until around 2500 when it seems to clear and revs smoothly up to the red line.
If you are aggressive with the throttle from tick over and press it down, it will shoot straight up and revs good.
I think there is too much air and not enough fuel going in when you open the throttle slowly...
What can cause it?
Any ideas on fixing it?
