Results 1 to 6 of 6
Thread: Cossy N/A Head high Spec for sale
    Jan 2011
    Germany , Munich
    Cossy Head,4x4 base,
    very high spec-
    320/308 cams
    solid Lifter
    big valve
    titanium spring retainer
    adjustable cam gears
    cam cover (a red one- not the green from the foto)
    ported to 27,5mm
    rar straight dcoe manifold
    50 er jenveys (without air horns)
    able to make 135 hp/l /9000+revs
    https://www.youtube.com/watch?v=d0yHY1YZaRY
    complete-give a little inspect-bolt on strong bottom end and have fun---
    3700 gbp plus ship
    not need anymore-i go back to pinto historic racing (the wild years are over )
    Attached Thumbnails Attached Thumbnails Cossy N A.jpg‎
    Apr 2020
    Essex
    96
    Re: Cossy N/A Head high Spec for sale
    Do the jenveys come with injectors
    Jan 2011
    Germany , Munich
    hello,
    no the rail and injectors are missing,
    but there was cheap-good used Audi s4 items-Bosch 0 280 150 951
    very nice spraying (4 hole) ones i use it in all fuel injected engines
    Spanner Monkey Mkdu's Avatar
    Oct 2009
    385
    11
    what an engine and the car on hillclimb video, great.
    why putting injector so far, what's the benefit versus on throttle bodies ?
    is the head still for sale ?
    24,345
    255
    Quote Originally Posted by Mkdu View Post
    the further away the injector from the valve the better for high rpm performance, fuel has longer to properly mix with the air flow, probably also introduces a small charge cooling effect, look at all the old cosworth DFV engines or the CanAm V8's they all had injectors either external or at the ends of the trumpets
  6. The Following User Says Thank You to Graham For This Useful Post:
  7. #6
    2,985
    112
    a bit off post but graham mentioned DFV which got me searching if you have 5 minutes watch the vid with guy martin
    https://www.youtube.com/watch?v=D6TsV20a29c
  8. The Following User Says Thank You to wildo105e For This Useful Post:
