Results 1 to 8 of 8
Thread: Looking for a Type 4 gearbox
    Jun 2015
    Munich
    62
    Need as a spare unit Type 4 gearbox if possible with bellhousing .
    Jan 2008
    Up the garage
    2,775
    218
    Re: Looking for a Type 4 gearbox
    What's a type 4 gearbox?
    Jun 2015
    Munich
    62
    [QUOTE=HonkyWhiteTrash;3701982]What's a type 4 gearbox?[/QUOTE
    Type E Rocket Box .
    3,239
    [QUOTE=Raffik;3701998]
    Quote Originally Posted by HonkyWhiteTrash View Post
    Type E Rocket Box .
    Two different things - its either a Type E box (as fitted to RS Escorts etc.) or a Type E box fitted with a 'Rocket Gearset' (which wasn't fitted to anything 'as std.')
    Jun 2015
    Munich
    62
    Click image for larger version Name:	gbox1.png Views:	68 Size:	9.7 KB ID:	85942
    Picture attached
    Jan 2008
    Up the garage
    2,775
    218
    Quote Originally Posted by Raffik View Post
    Attachment 85942
    Picture attached
    As stated above, a normal Type E gearbox has wide ratios, whereas a Rocket gearbox has close ratios with 2.54:1 first gear. A Rocket gearbox is rare and expensive if you can find one. And replacement gears are like hen's teeth.
    I do wish people would stop refering to bog standard 4 speed Cortina gearboxes by the name Rocket.
    As Honky has already mentioned in his post a Rocket box was a close ratio competion gearbox with helical cut gears and was sold by Ford RS dealers only. The ratios were Homologated for Group 1 Rally cars. These gearboxes aren't to be confused with the Tran X straight cut version of this box that had the same ratios.
  8. The Following 3 Users Say Thank You to Forest_rallying For This Useful Post:
  9. #8
    Jan 2013
    Kingston,Jamaica
    33
    317
    I have a complete gearbox if still needed
