What the maximum overbore can an early 1600 pinto block take. I’ve read a few posts about folk taking the out to 90mm but can they go a bit further? 92mm 93mm.
Are the standard crank strong and rods strong enough to handle anymore more power?
I’m not looking to build a cheat engine for motorsport or anything like that...if I do anything with it it will just be a road going engine.
I’ve just got an old 1600 pinto sitting in the corner of my shed that came out an old Mk4 cortina and I’m just thinking of a little side project to fill my time and if I can turn it into something a bit special then I might even consider putting it back in the cortina instead of going down the Duratec route. I’m not looking to build a cheat engine for motorsport or anything like that...if I do anything with it it will just be a road going engine.
Ive already read posts about use a 2L crank but just looking for information regarding building up an engine using the original crank and going for a larger bore.
cheers,
Kev
