Page 4 of 4 FirstFirst 1 2 3 4
Results 121 to 144 of 144
Thread: Big Wing Mk1 Escort Pinto Project - Restoration no.3
  1. #121
    Mar 2016
    North Wales
    238
    15
    Re: Big Wing Mk1 Escort Pinto Project - Restoration no.3
    O yes, make sure you have the right configuration for which side your exhaust is running, I didn't and had to cut out the towers and refit.......doh!!!!
  2. The Following User Says Thank You to waverunner For This Useful Post:
  3. #122
    Aug 2020
    South East
    235
    326
    Quote Originally Posted by waverunner View Post
    Your rear set up is exactly as mine, don't forget to load the axle into its running position before you weld the watts towers.
    Thanks, that's a point I may well have overlooked.
    Towers are miles out, especially the N/S one (which is the short one in this case as I'm going for R/H exhaust exit).
  4. #123
    9,204
    Quote Originally Posted by RS2OOO View Post
    Now looking more like a car again.
    Watts Linkage (the more expensive kit from MST) towers are miles out and need plenty of work.
    Don't know whether to take the car home and dry build it including any drilling and cutting that comes with that before stripping again and sending for paint, or getting it painted right now and being very careful with the drill when rebuilding.... I'd be interested to know what you would do?
    i cant remember what drive train your fitting but that gearstick hole is way back on standard ?
  5. #124
    Aug 2020
    South East
    235
    326
    Pinto and a type 9. Engine and box bolted up before making the gear lever hole so it should be ok.
    Sent from my Pixel 4a using Tapatalk
  6. #125
    9,204
    i have fitted a t9 using the square hole in auto tunnel - unmodded. with a std shell only 1/2- 3/4 of the tunnel strengthner needs trimming out , yours is removed going on pics so no ref to this but the hole is way back from auto hole.
  7. The Following User Says Thank You to alladdin For This Useful Post:
  8. #126
    Aug 2020
    South East
    235
    326
    If you zoom in on pic you can see the original auto tunnel hole (where its welded up). About half the new hole overlaps where the auto hole was, so the new hole centre is about 2" back from the auto hole centre.
    Engine back out the car now but looking at the pics with the block in it does look to be sitting far back against bulkhead leaving me wondering if the head will clear the heater bubble lip.
    Everything should line up ok but definitely worth a closer look before final paint to be sure.
    So maybe after all I'll do a full dry build before final paint. (Not got enough money left for paint anyway so not much choice in the matter).
  9. #127
    Mar 2016
    North Wales
    238
    15
    Are you fitting anti tramp bars?
  10. #128
    9,204
    and a question from me too ( maybe both of you will be able to help )
    i notice you have gone for gaz shocks - i have been looking at early fitment ones myself and it seems to be gaz or AVO for sensible money.
    any reason for your choice ? any info on pros and cons ?
  11. #129
    Aug 2020
    South East
    235
    326
    No reason at all mate and I don't know how they'll perform. Out of all the shocks currently available the Gaz seemed to offer most bang for buck, and being adjustable you can soften up for the drag strip and play around with settings for the road.
    On top of that there seemed more limited options available for early fitment types and these were less than half the price of Bilsteins.
  12. #130
    Aug 2020
    South East
    235
    326
    No.
    Did plenty of research on this forum before deciding to go with this set up and concluded anti tramp bars were not necessary.
    Using my questionably dodgy (see pics earlier in this thread) leaf spring set up I've never suffered from axle tramp anyway.
  13. #131
    Mar 2016
    North Wales
    238
    15
    I'd seriously reconsider with regards to tramp bars, its all about axle location. Your going full on restricting sideways movement with the Watts kit but your not addressing the axle twist movement, and believe me, with any increase in standard 1300cc x flow hp, you will get twist.
    I have Gas shocks too and can't praise them enough. I'm running a LS1 cams, BDG with your set up (with RS anti tramp) and in all honesty, going round a circuit with sticky tyres, the car handles like a dream.
  14. #132
    9,204
    i would also recomend anti tramp bars, in my opinion they are an absolute necessity. fit them now before paint and its an easy job ( other than axle is finished !)
  15. #133
    Aug 2020
    South East
    235
    326
    I honestly think it should be ok as with the inverted leaf spring set up I never previously had tramp anyway. Unless of course the addition of the Watts kit induces tramp because the energy no longer has anywhere else to go.
    I think I'll stick with just the Watts setup, maybe (you have got me thinking about it now) but will equally come back and say I f*cked up if I'm wrong and it tramps all over the place!
  16. #134
    9,204
    at least fit chassis brackets, you dont need to use them ( but you will once you drive it )
  17. #135
    Aug 2020
    South East
    235
    326
    Ok, I give in, tramp bar kit being ordered tonight.
  18. #136
    9,204
  19. #137
    Mar 2016
    North Wales
    238
    15
    You gave in easily........ your misses must love you!
    You won't regret it..........
  20. #138
    Aug 2020
    South East
    235
    326
    Tramp bar kit arrived from Motorsport Tools today - with Rally Design part numbers on the components. Could have saved £12 if I just bought from Rally Design!
  21. #139
    2,659
    268
    Yea, there are a few parts like that from various different suppliers.
  22. #140
    Aug 2020
    South East
    235
    326
    She must do, she was stuck for a Birthday present so paid for the Anti Tramp Kit!
  23. #141
    Aug 2020
    South East
    235
    326
    And now fitted:
    And Firewall welded up airtight:
  24. #142
    Aug 2020
    South East
    235
    326
    Fabrication work all finished pending a dry build where I'm sure a list of new things to fabricate will be found.
    Tucked out the way in a container while house move in progress. Things likely to go quiet on the rebuild front for a good few Months now.
  25. The Following User Says Thank You to RS2OOO For This Useful Post:
  26. #143
    Tyre Kicker HOL's Avatar
    Feb 2009
    Kent
    22
    How is this coming along now?
    I seem to have caught and overtaken you. Albeit standard arched.
  27. The Following User Says Thank You to HOL For This Useful Post:
  28. #144
    Aug 2020
    South East
    235
    326
    Quote Originally Posted by HOL View Post
    Attachment 88821
    Hi mate,
    Yours is looking good! Overtaken me by a good margin.
    I've not done a single thing for over a year.
    Moved into a doer upper House, which is only about 50% done so far, but I have been collecting bits and pieces for the car. Not a day goes by without me thinking about it.
    I've saved up the cash to get it painted, which brings me to the dilemma.....
    Do I continue with my original plan to dry build the car first before sending it off for paint, or do I just send it in for paint knowing that will properly motivate me to get it built?
    I know the first option is the better one, but struggling to get the mindset and the time to do it.
    Sent from my Pixel 6a using Tapatalk
  29. The Following User Says Thank You to RS2OOO For This Useful Post:
    HOL
