Ford escort mk1 1300 sport 1971
Hi. I need the help of this forum to solve a big problem on a FORD ESCORT MK1. A friend has a 1971 ESCORT MK1, model 1300 Sport.
In the data sheet made in 1971, the front and rear axle weights do not appear. This friend made some modifications last year in the car that required, in order to legalize them and be able to circulate with the car, of an engineering project with a mechanical engineer. So far, good,but when he went to the technical inspection of vehicles when he did not having those axle weights you cannot pass the inspection and therefore you cannot drive the car.
In order to make the new technical data sheet, my friend needs a technical data sheet for a vehicle with the same characteristics from the year 1971 and the Sport 1300 model. Other technical data sheets from other models have been taken to the engineer and it is not worth it. It is a question a bit absurd since the difference in weights of the front and rear axles of the Escort MK1 models must be small or null.But that is what they ask of you and that is what I ask of you ...... a data sheet of a 1971 ESCORT MK1, model 1300 Sport.
Can someone send me a technical sheet in pdf format to my email cesareofelipe@gmail.com?
Thank you very much in advance for your help.
Best regards.
Cesar.
Re: Ford escort mk1 1300 sport 1971
1300 Sport is 805kg with 437.1 kg over the front axle and 367.9kg over the rear.
I only have that information written down as I copied it by hand from a microfiche at a Dealers I worked for years ago along with a load of other useless information.
