Good day all.
As the subject says, I have a set of NGK for my tuned pinto. Whats the gap please? Many thanks.
Good day all.
straight out the box is just fine
If you are using a points type ignition or a points-replacement electronic ignition (like Ignitor I) use 0.7 - 0.8 mm.
If you are using a good electronic ignition (like Lumenition Opto) use 1.0 - 1.1 mm.
Thanks. Yes I have acuspark electronic ignition.
Don't mean to hijack Murrays tread, but which do you recommend for Pinto on carb(s), Miniliteman?
For any high performance engine I would recommend the Lumenition Performance Ignition System.
It is a proved reliable, robust system. And as it uses an opto-sensor it is very much less prone to interference.
https://www.burtonpower.com/lumeniti...it-cek150.html
