Odyssey PC950 Extreme Racing 30 Starter Battery
I am looking at one of these BATTERYS to go in my PROJECT. RWD MK 6 FIESTA running ST170 ENGINE on bike carbs , the battery will be mounted under pass side seat,
QUESTION ...
will it be able to start / run it OK. powerfull enough ???
any feedback will be helpfull
cheers mike
Re: Odyssey PC950 Extreme Racing 30 Starter Battery
yes easily.
the only thing you have to bear in mind, is that it wont have a lot of reserve capacity, it wont crank the engine for long periods or lots of times without needing a run or a charge. so best have a slave battery to plug in when just shunting the car around
Hi graham.
Thanks for this info. This is one area I'm not to clued up on. Normally just use a ordinary car battery . But cause I want to fit this inside cabin . Looking at these types of battery.
