DGAS idle air bush location/replacement
Can anybody point me in the right direction of the air bushes on a 38 DGAS? I've stripped one down to clean/service and rejet. I have read that it's best to replace the bushes to suit the jetting and have them ready to go but can't see where they should be?
Thanks in advance!
Re: DGAS idle air bush location/replacement
Locate the 2 idle jets / idle jet holders.
In the top of the carb body you will see 2 pressed-in bushes just above where the idle jets are located.
Ohh yes, i see! That's a great help, thanks. I was assuming they would be at the base of the jets.
