hi,
Does the red circle indicate the correct location for the engine breathing tube on an n/a cosworth?
regards, Ruud
hi,
regards, Ruud
It might be, you need to take a look where in goes to in the cylinder head.
When we ran NA Cosworths back in the 90's we had the breather pipe in a similar position but possibly slightly to the left of the red circle. If you look on the cylinder head there's a round hole that goes straight down in to the block, thay's where we always had the breather pipe.
Can you post a photo of the underside of the cam cover Ruudje?
