Rally mud flaps
Has anyone fitted rally mud flaps to their escort mk2. If they have what did you use for a template and where on the outer wing did you fit them.
Re: Rally mud flaps
Mine are mounted using little brackets that are readily available, search Escort rally mudflap mounting brackets.
Pattern, just make one up out of cardboard.
The Following User Says Thank You to larrythelabrador For This Useful Post:
Re: Rally mud flaps
You can buy moulded mudflaps from MS Tools that do away with the need for brackets.
The Following User Says Thank You to Forest_rallying For This Useful Post:
