Corsa B power steering
I have 3 corsa b power steering units which i kept as spares
2 have not been altered and ready to be converted, come with ecus
1 was fitted to my own car for over 5 years with no issues, comes with ecu and bolts to original mk2 mounts and will take mk2 switch gear and steering wheel, i changed my bias pedal box to a new gartrac unit but the cylinders touch the back of the motor so ideally you will either need to have angled cylinders or no bias pedal box, it will clear a dash bar from the new safety devices bolt in cage
£175 for unaltered units or £300 for the other, wouod do a package deal on all 3 but due to weight would need to be collected from either Plymouth or Exeter by arrangement
Re: Corsa B power steering
