C20XE Alternator
Hi, I need some help please on the alternator I should be using on my c20XE fitted to my Mk 2 escort build - Its currently got a Lucas LRA871 fitted but the fit on the M8 5" pivot bolt is very sloppy ( hole in the alternator is about 8.35mm). should I be using another alternator or is the 871 usable?.
Re: C20XE Alternator
Hi, take a look at my post. I changed the BIG one to an alternative for Daihatsu. This is the same which you can buy with the name Wosp. But this 60 AMP is cheaper!
http://www.turbosport.co.uk/showthre...09#post3729309
Ebay Link
https://www.ebay.de/itm/Lichtmaschin...item2d0253691b
