Results 1 to 8 of 8
Thread: Oil capacity pinto with RS sump question
    Dec 2009
    Netherlands
    413
    19
    hi,
    Multiple sources tell me the oil capacity of the 2.0 pinto with RS sump incl filter is 3,8liters.
    However, if I poor in 3,8 liters the dipstick 'says' there is way too much oil in.... (The dipstick and tube are correct in length).
    Does this have to do with the engine angled backwards in my escort mk2 RS or am I missing something else
    regards,
    Ruud
    25,110
    Re: Oil capacity pinto with RS sump question
    have you run the engine? the oil filter alone will hold about .5 litres
    Mechanic snapper1's Avatar
    Oct 2010
    Chelmsford
    67
    668
    27
    I would spin up the oils pump through the dizzy hole or if you don’t want to pull the dizzy then plugs out spin up on the starter to get oil in the filter and gallery’s and dip again.
    The oil level is relative to the block face to prevent crank weights frothing it up or pickup sucking air.
    RS2000 has a basic wind age plate.
    Pinto’s are fitted rear down and sump is at the rear so your fairly safe but hard braking or cornering could throw a bit more oil about
    Dec 2009
    Netherlands
    413
    19
    Hmmm...still a mystery unsolved.
    I've added approx 3.2liters. Let's say there was still 0.2liters of oil in the engine. Total of 3.4liters.
    Car stands level. Pinto bottom end with RS sump amd original box is fitted in my original mk2 RS. Engine has spun over.
    Dipstick says it's at it's max level.
    Weird.
    Oil pressure is excellent though, but I reckon my oil pressure will even be good with 1 liter of oil in.
    4,888
    Quote Originally Posted by Ruudje View Post
    Are you 100% sure?
    Dec 2009
    Netherlands
    413
    19
    Are you 100% sure?
    Jip. I've measured it twice. Comparing 3 different mk2 RS engine blocks which are all the same...
    Jan 2008
    Up the garage
    2,775
    218
    Weird.
    Did you fit a new oil filter? Did you prime it?
    Dec 2009
    Netherlands
    413
    19
    Quote Originally Posted by HonkyWhiteTrash View Post
    Yes I did and Yes I did
