Pinto engine
Hello all, just taken the head off my 2.0 pinto and found all pistons numbered 3 and are 0.10mm under the top of the block at tdc,is this normal?its also got a fr33 cam. Can the head be skimmed 0.5mm safely?
Re: Pinto engine
the block has been faced in the past, high comp pistons are around 0.5mm down on an unmachined block face.
you can take 2.5mm off a pinto head so 0.5mm is defiantly no problem
Re: Pinto engine
So going to be quite high compression ratio, should work well with the fr33?
Re: Pinto engine
wont be that high, just over 10.1 depending on head gasket
