Allo chaps & gals, first time posting here. (Also made a post on passionford)
I post most of my stuff to a build thread on fiesta-mk1.co.uk, thought I'd share it here. Hi sam.
1978 Mk1 Fiesta Model 950cc 45HP project, swapping in an ST170 with a Escort Mk5 TD / Orion 5 Speed MTX75 gearbox. Will be driven daily. Acquired the car in mid 2019 and drove it for a few months, then my brother put ideas of a Zetec turbo in my head & it wasn't long before I picked up a complete St170 + 6 speed getrag box for £200. First thing we did after getting the car was swap the front suspension out for modified corsa coilovers, quick hit up with the die grinder got them on and modified the top mounts to suit. See pictures.
Started doing my homework on how to approach it all & finally found the gearbox I wanted at the end of 2019. Rebuilt the engine over the last winter and earlier in 2020 I pulled the Valencia engine out to size up the St170. Cut the chassis rails on both sides and reinforced them with 3mm steel plate, made my own mounts with the help of my brother and father. The rubbers for the mounts are from the leaf spring setup on the back of a transit so they are plenty man enough. This was after I modified a existing CVH mount but just didn't like it in the end. Bought brand new Focus driveshafts for use with the gearbox, the half shaft is now mounted on a modified Focus mk2 bracket. Runs true. Making the exhaust manifold right now with the inlet manifold partially cut out of 45mm ally tubing, just needs tigin' together.
Next big hurdle is turning the driveshafts on the new lathe I recently setup, I've got a plan for it. After that its just the usual manifolds, breaks etc.
Engine Management: Motorsport Electronics ME100 / Speeduino. Both will be on a common loom so I can run the ME100 until I've finished writing the cam sensor decoded to run the VVT correctly in the speeduino firmware.
All of the work installing, making/designing, painting is done by myself, my brother & my father. We don't have access to any fancy water/plasma cutters or CNC mills, so my brackets may look a bit rough and ready but when the time comes I'll draw them up and order some proper looking kit to tig up when the time comes to paint the car next year.
Parts list thus far:
2.0 St170 Engine 110k Miles
Escort Mk5/Orion TD MTX75
1.8 Zetec Silvertop sump + oil pickup
MTX Rod Gear remote
Valhalla corsa coilovers modified to suit (DIY)
Zx9R Carbs with a preinstalled jet kit
Zx9R fuel pump
Mk1 Focus OEM Lightened flywheel
Mk1 Focus brand new drive shafts
230mm clutch kit
ME100 / Speeduino
AEM AFR Sensor + gauge
Brand new zetec waterpump
Billet reverse waterpump impeller
45Amp Denso alternator
Clutch arm for gearbox (was missing)
Brand new Airtec Mk2 XR2 Radiator
4 pot breaks for the front
Mk1 Focus rear hubs to attach to the rear axel for disc breaks on the rear (soonish)
God knows what else at this point
I only recently got a new camera so the early photos may be lacking in quality, sorry about that. WARNING: HELLA TON O IMAGES AHEAD
