Results 1 to 17 of 17
Thread: New pinto first start up
    Oct 2018
    Midlands
    291
    Hi just fitted newly built pinto.all new.stage 3 head rl31 cam 10.5.1comp i was going to turn engine over with plugs out get oil up.dizzy in so dont want take it out to spin up with drill.then was going to start it and keep revs up around 2k for twenty min or so. Does this sound ok? Only trouble is i have new twin 45s with base settings sould this be good enough start.dizzy set at 12% advance.any info tips cheers
    25,110
    Re: New pinto first start up
    Quote Originally Posted by Theyellowmex View Post
    yes, but winding the engine over on the starter to get oil pressure up is the last thing a new cam wants, far better to pull the dizzy and use a drill to get pressure up.
    even with jetting a fair way off, you should be able to hold around 2000rpm
    Oct 2018
    Midlands
    291
    Thanks graham.thats bit of a pain didnt want take dizzy out again now timings ok.theres plenty of lube on cam and not put oil in yet was going to put oil in just before starting thinking there would be plenty oil in rocker area?
    Apr 2020
    Essex
    210
    Mark the dizzy before you pull it out! Prime the pump and refit dizzy, start it up
    I had staring issues with a crossflow years ago ruined the camshaft!
    25,110
    its not so much about the oil, its taking the load off the nose of the cam lobes. with the cam turning at speed the opening ramp in the cam gets the valve train moving quickly and gives it inertia so theres less load on the nose of the cam, kind of like when you seriously over rev an engine and the valves hit the pistons because the valve train has lost contact with the cam, but not quite as extreme
    Oct 2018
    Midlands
    291
    Is it just matter of removing dizzy and then use drill to spin it up? Crank and cam stay at tdc? I thought dizzy worked off cam belt aux pully.what size drill bit/hex excuse me for my ignorance. Cheers
    25,110
    Yes as long as you put the dizzy and rotor arm back in the same place, from memory the oil pump drive is a 6mm hex, i spin it up with a quarter drive extension and small socket on the end, battery drill is good enough, it doenst matter what the oil pump is i always see at least 60psi with cold 20/50
    25,110
    9,200
    its the same hex as a std battery drill accessory as far as i remember either 1/4" or 6mm as graham says.
    mark rotor arm position and dizzy position before removal and i would retime static after refitting - its only 5 min.
    It needs to be a long reach socket of 1/4 drive.
    Apr 2013
    S Wales
    230
    431
    Click image for larger version Name:	240 320.jpg Views:	66 Size:	71.1 KB ID:	86325
    6mm socket on an electric drill.
    Oil pressure gauge in car also was reading pressure, but don't recall how much.
    This confirmed my spray bar was all good. You can see fresh oil coming out of spray bar onto cam.
    I used a sharpie marker on my Dizzy for position.
    make sure you drive it the right way (don't ask)
  13. The Following User Says Thank You to wildo105e For This Useful Post:
  14. #13
    Oct 2018
    Midlands
    291
    Cheers guys for info.has site been down not neen able to get on for couple days.
  15. #14
    Oct 2018
    Midlands
    291
    Im assuming it clockwise same as dizzy lol
  16. #15
    One way makes you think oil pump issues engine out total disappointment.
    The other way works.
    Can’t remember which way.
  17. #16
    25,110
    yes
  18. #17
    I have had a couple of days when it was very slow amd virually impossible get on the site.
