Originally Posted by
Jdmphil Ok I’ve a b series Honda engine in shed I’d love to to get it into my mk2 but as u know the engine rotates anti clockwise I had a thought the other day if I flipped the diff it would it wound counter rotate it my question is has this ever been tryed and Is it possible to do probably with correct diff set up problem I was thinking is the gearbox would be turning backwards would this cause damage to box I was thinking a t9 or Mazda with an adapter plate or if the t9 had straight cut gears might even be better and then the diff is it possible be turn the diff or would I have to turn the axle the car at moment has a Borg rear diff running a 1.3 auto so will be replacing the new axle new box new engine trying to make a plan make up my mind wat to run but would love to the b series in it as be different and cheap to upgrade down the line I know u can get a Gforce box to rotate correctly but 5k bit much for a box for me basically any thoughts can it be done is there a diff I could buy to counter rotate and best axle set up to be able to do this
