Results 1 to 4 of 4
Thread: st170 to maxda rx8 box, new starter,otor.
    Sep 2020
    south wales valleys
    62
    183
    Hi All.
    As some of you might know my project car is gona be running st170 engine, 2.0lt flywheel lightened and balanced and drilled for pinto clutch, to rx8 6speed gearbox. my question is what starter motor would be best, i have found this bit of info ,but would like peoples option / advise on it, THANKS
    Starter Motor
    If using one of the standard Zetec flywheels, you will need a starter motor from a Ford Sierra with a 1.8 CVH or 2.0 DOHC engine. The Lucas part for this is the LRS707. If any of the standard Zetec flywheels, you will need the starter motor from any OHC Pinto based Sierra from 1982-1989 or any CVH based Sierra from 1987-1993. This is a Lucas LRS543 or equivalent.
    Please be aware that this is available in two variants with different diameter motor housings, one around 3½" in diameter and the other around 5" in diameter. The one with the lager diameter motor housing will not fit and will foul on the sump. Therefore, you will need to specify the smaller diameter model.
    9,211
    Re: st170 to maxda rx8 box, new starter,otor.
    given your ability i would suggest re making the adapter at starter position to use the std st170 starter. this is a higher output and obviously matches the zetec FW. and its compact. can also move up under inlet if needed. the lrs 707 as above is pinto pattern and zetec fw compatible ( 15mm ish different throw.) the info above is a bit confusing as i think its a typo and secont part should read pinto flywheel ?
    for a pinto clutch it was a std pinto bearing i think ? but i guess yours is hybrid rx8 anyway for bearing.
    Sep 2020
    south wales valleys
    62
    183
    Hi Aladdin.
    First things first,, HAPPY NEW YEAR,
    As you may know i got st170 engine with adaptor plate for rx8 box, new sprigot bearing to suit, mazda clutch bearing running pinto cluch as i had the new 2.0 zetec flywheel lightened and balanced, as i got rid of the dual mass that was on the st170 engine. also the starter was sold off as i new it wouldnt fit my combo.
    as i havent bolted it together yet , not sure whats needed, i seem to fav the lrs707 , but i not sure on fittment yet, as you read so many different things regarding starter fittings / workings. and i would like to fit the high torque version ( wasp type ). hope this explains it abit.
    cheers mike
    9,211
    yes, the difference is that ring gear on zetec flywheels is placed about 15mm different to pinto so you need a starter to suit, adapters have fit for pinto pattern so lrs707 will do it. but i would go for a mod and use an st170 std starter - high torque as std i think. and cheap n easy to replace.
