Results 1 to 4 of 4
Thread: Brake pipe
    Jul 2015
    Slovenia
    15
    Brake pipe
    Hi.
    Can anyone tell me what the dimension of this vacuum tube is?
    Only for LHD (The image is symbolic)
    Click image for larger version Name:	Brake pipe.jpg Views:	41 Size:	144.0 KB ID:	86360
    3,242
    Re: Brake pipe
    !2mm outer / 10mm inner from memory and a bit of guessing!
    Re: Brake pipe
    If you haven't got a set of vernier calipers to measure the outside of the steel pipe then use an open end spanner and see which one matches the size of the pipe, the pipe should slide neatly inside the jaws of the spanner of the appropriate size. This's only for a rough guide but it should give you the answer you need but beware the pipe might be an imperial size.
    The size does look similar to the post above.
  5. The Following User Says Thank You to Forest_rallying For This Useful Post:
  6. #4
    May 2004
    Norn Iron
    1,143
    Re: Brake pipe
    Looks like about 12mm or 1/2" OD.
    Ultimately it's not critical, anywhere 10-12mm will be perfectly fine if you're trying to replace it.
    Some modern cars it'd be as small as 8mm OD.
