Results 1 to 3 of 3
Thread: MK1 Escort .. fitting 2.0 pinto engine in .. problem with alternator space
    Jan 2012
    MILTON KEYNES
    Hi , got standard escort MK1 ,didnt realize the mk1 was bit narrower , lockdown project to relieve boredom .fitting pinto engine into it come across a problem , used rs2000 brake tower servo , got to the point of fitting the alternator against the tower and space is very small and a problem , compared to a mk2 engine bay fitted with pinto using exactly the same tower ,alternator mount etc , the mk2 bay is wider and has fair bit more space by alternator ,
    SO.. is the mk1 rs2000 alternator mount the way to go ? seen a pic of one it seems to lower the alternator downwards does it ? dont really want to loose the tower as its all been piped up now with new pipes , but will do if needs be ....
    Anybody able to advise , looking like lose the brake tower ? or sell me the alternator mount etc / parts / part numbers etc etc ,be appreciated even for a different brake master cylinder set up ... Any advise be gratefully received .. Thanks Dave.
    4,889
    Re: MK1 Escort .. fitting 2.0 pinto engine in .. problem with alternator space
    Can you post a photo?
    Anyway on the left is a std Pinto mount, on the right an RS mount.
    (post 6 on the thread)
    http://www.turbosport.co.uk/showthread.php?t=284311
  3. The Following User Says Thank You to Miniliteman For This Useful Post:
    Jan 2012
    MILTON KEYNES
    Thanks for that usefull info ,just need to buy myself an rs mounting
