hi anyone got a oil pickup pipe for a ralloy sump
or has anyone modified front wheel drive one to fit
sorry should of made it clearer the thread is in xe installation mk2 escort with a c20xe engine .about to buy a ralloy steel sump but just need a pickup pipe i have standard fwd pickups and i have a manta pickup just seeing if anyone has one or put me in the right direction
Sorry I have only just realised it was in the XE section, not somewhere I look very often.
Have you tried contacting Ralloy direct? they have always seem very helpful when I have ever phoned them. Failing that you could always try Yuk Hodgson.
no the don't make the pick up pipes thanks for the reply forest rallying
Hi, at the sbd Motorsport homepage you can get this instruction sheet.
https://www.sbdmotorsport.co.uk/inst...-modification/
Manta_pick_up_pipe_and_16v_baffle_modification.pdf
thanks sk
