Results 1 to 10 of 10
Thread: spot light diagram
    Feb 2009
    aberdeenshire
    893
    88
    spot light diagram
    can anyone give me a easy to follow diagram for wiring 4 no cibies to my mk2 escort please? do i need 2 no relays? thanks steve
    3,001
    Re: spot light diagram
    The info is all out there, if you can be bothered to look for it!
    http://www.doublegmotorsport.com/rsp...-Electrics.pdf
    And yes, two or more (original headlights as well) relays are advisable.
    Feb 2009
    aberdeenshire
    893
    88
    thanks katana, its not i cant be bothered , am not great on internet. thanks again for the reply
    Feb 2009
    essex
    2,043
    Quote Originally Posted by mk2 stevie View Post
    fog light relay
    85 earth
    86 side light feed grey/red or grey/black from the head light
    87 to the fog lamps
    30 power suppy from battery
    spot lights
    85 earth
    86 power supply from full beam white wire from head light
    87 to spot lamps
    30 power supply from battery
    Feb 2009
    essex
    2,043
    Quote Originally Posted by jimmy2006 View Post
    fog light relay
    85 earth
    87 to the fog lamps
    spot lights
    85 earth
    87 to spot lamps
    when you use the switchs to cotrol the relays wire it in on the 86 terminal
    Feb 2009
    aberdeenshire
    893
    88
    if you was going to use switchs to turn the lamps off / on put the switch on the 86 terminal were you are controlling power for the relay goes
    thanks for info jimmy, appreciated
    Feb 2009
    essex
    2,043
    3,157
    spot light diagram
    Relays with fuses in are a great thing and save extra wiring if you are just fitting a couple of relays
    Feb 2009
    essex
    2,043
    yes i use them a lot from Durite
    the relay part number is 0-726-12
    and the relay holder is 0-729-01
    but you will need to buy a pair of crimpers Un-insulated there about 30 or you can find cheaper one like EBay the part number on my ones are 0-703-50 or i have the 0-703-51 for the superseal terminals so you can put the lamp on plugs
    Feb 2009
    aberdeenshire
    893
    88
    thanks for the replys lads
