Originally Posted by
Graham what are you using for a co meter? 8% at idle on a warm engine usually results in fairly rough running, are you sure its that rich? if its a diy type meter its reading could be way off. another possibility is you have an intake air leak somewhere, which means the idle speed screw needs to be screwed so far in to make it idles, the carb is actually drawing fuel through the main jets, if its idling on the main jets if you look down the carb with the engine running you will see fuel dribbling from one of the aux vents
