Results 1 to 2 of 2
Thread: speedodrive T9...plastic gear ok...but not spinning
    Jun 2009
    D
    336
    my speedo does not work (it never worked since the car came to me). speedocable is ok.
    so i took-out the plastic speedo-drivegear from the gearbox....and its not worn....also tested with a new one
    investigated through the big hole if the (steel)gear inside the gearbox is spinning: yes it does
    but it loks like the 2 gears do not engage deeply enough when assembled. for me it looks like the gearbox gear sits to far to the rear
    is it possible that , if the gearbox was refrubished in the past, somebody did a mistake in assembling the output shaft in a wrong position?
    Click image for larger version Name:	4aablwmf.jpg Views:	27 Size:	89.0 KB ID:	86613
    Jun 2009
    D
    336
    Re: speedodrive T9...plastic gear ok...but not spinning
    i think i found the answer here:
    https://www.lotus7.club/forum/techta...m-output-shaft
    the worm-gear may have walked away or was fitted in wrong position during a past rebuilt of the box....i expect the later one.
    as the local garage who took care abouth the car for the former owner did all wrong....nearly all repairs or maintenance during the last 10 years were not made correctly (but the owner paid huge bills)
