Morning all,
Just a general enquiry but here is the background. My duratec install is complete except awaiting my exhaust from Ashley. So whilst bored i decided to do a compression test on the engine cylinders 1,2 and 4 pulled 100 with throttle shut cylinder 3 pulled 50 the numbers i think are irrelevant but the difference in the numbers to me seem very relevant.
Tested again with wide open throttle and 160 -170 and 100 for cylinder 3. So obviously cylinder 3 on my £150 gamble engine is down.
Is it worth doing a leak down test with a cheap tester and will it tell me any more ? it may not be the cylinder but a valve ?? sort of thing.
I have a spare engine now tested that and it pulled 160 on all 4 cylinders when tested on the garage floor so not crucial i getting the installed engine perfect i just hope it will run enough for initial testing etc
