Results 1 to 8 of 8
Thread: Fuel pressure regulator position
    Nov 2013
    france
    75
    103
    Hi guys
    Escort mk1 with twin 40’s
    Where does one mount the fuel pressure regulator (filterking )
    above or below the top of the carb inlet ?
    Nov 2013
    france
    75
    103
    Re: Fuel pressure regulator position
    Also
    On the bulkhead or wing
    doesnt really matter..............
    mine is right next to my fuel pump in the boot. It is pressured so as Graham says cant see how it matters.
    Quote Originally Posted by escortservices.fr View Post
    Hi guys
    Where it's at its coolest.
    When we built our first NA Cosworth engine Escort Rally car we had awful trouble with it misfiring for the first mile or two after sitting on stage starts in very Hot weather. The engine was fitted with a plastic mechanical fan on the water pump and the filter king was bolted to the inner wing right inline with the hot air being moved by the fan. The hot air was hitting the filter causing the petrol in it to evaporate resulting in the carbs being short of fuel. Filter moved and the problem solved after lots of head scratching.
    Feb 2016
    Gloucestershire
    65
    In the boot by the pump, worked fine on the works bda cars.
    Mar 2016
    North Wales
    238
    15
    Inner wing under the carbs, not in the boot, as recommended to me by Wayne Mitchell.
    Mar 2008
    North Wales
    214
    10
    I mounted mine above the instrument cluster.
    Well I thought it looked cool
