Originally Posted by
Graham its nothing unusual, the marks closest to us in the picture are pretty normal start up run marks where there has been very light contact between crank and bearing, perfectly normal. The marks at the top of the picture are heavier, defiantly contact, possibly the shell wasnt located quite correctly, or maybe the rod wasn't it spotlessly clean where the bearing sat, but either way its had contact but it would say its now got the clearance it actually wanted, which is just fine if the shells are still a nice fit and the rods and you put them back where they came from
That bearing looks to be in very similar condition to those in my "dyno dog" pinto, i just put them back again after doing a ring change, and have put numerous warm ups and 100 odd dyno pulls on them since. Dog still has 62psi oil pressure @6000 @80 degree C oil temp on a bog standard untouched oil pump
