Type 9 vs RS2000 Type E gearbox
Hi all,
Does anyone have dimensions of a Type 9 gearbox alongside a RS2000 Type E rocket gearbox? From the front of the main housing to the tail? Or a picture of the two side by side?
I'm specifically interested in the difference between the gearbox crossmember mount position i.e. I believe it's further back on the type 9? Is the gearstick hole in the same position?
Thanks in advance.
Re: Type 9 vs RS2000 Type E gearbox
the gearboxes are the same length, gear lever comes up in same position, and yes the mount is further back by about 50mm from memory
Thanks Graham. Good to know.
