Hi Guys,
Im a long time lurker and proud owner of a mk2 Mexico.
I need a bit of help from the collective.
Im currently building up my Pinto and have had the crank re ground.
I have carefully measured the bearing clearances with Plastigauge and have the following which seem a bit loose to me.
Mains:
No1 0.050mm
No2 0.050mm
No3 0.063mm
No4 0.063mm
No5 0.063mm
Big Ends:
No1 0.076mm
No2 0.076mm
No3 0.076mm
No4 0.063mm
I know a lot of people dont like or trust Plastigauge but I used a reputable machine shop and they said I dont need to check clearences anyway as long a I buy good quality shells of correct size. (Mains +0.25) Ends (+0.50)
I have bought the shells as recommended from Burtons Mahle VC.
Any help or advice greatly appreciated, its my first engine build and I really dont want to put it all back together only to have either no oil pressure or a tight engine that knock the bearings out in no time.
Many thanks in anticipation.
