Ignition wiring
Advice required. When I turn my ignition to stage 2 the engine cranks over when the ignition lights should be on, when I then go to the engine crank position the ignition light come on
to start the engine I run a live from the battery to the black and yellow ignition Live wire and the lights come on immediately even without the key in the ignition, changed he ignition barrel wiring and it’s the same
any ideas
Re: Ignition wiring
quick guess, blk/yel and blk / red swapped at starter solenoid ?
Re: Ignition wiring
Thanks Alladdin, tried that and nope, baffled but at least she runs
It will be something simple so have an auto electrician coming to have a loom next time I am back
Re: Ignition wiring
