Results 1 to 2 of 2
Thread: Brake servo
    Aug 2021
    israel
    24
    Brake servo
    Click image for larger version Name:	SERVOLE72696_Remote_Servo_Kit.jpg Views:	47 Size:	9.7 KB ID:	87338
    Hi friends has anyone assembled a brake servo and can explain the process or with there are pictures from the process or how to assemble it? About Escort mk2
    Tank you tom.
    3,241
    Re: Brake servo
    About as simple as it gets - using that picture as a guide - 1. Brake fluid line from outlet of master cylinder goes into servo at the back blue plugged port. 2. Brake fluid line from front blue outlet of servo 'snout' goes to brake system (discs only or drums only or both) 3. Vacuum hose from inlet manifold goes to servo through yellow capped spigot. Job done.
