Re: 44 idf vacuum pipes
The official (homologated) way is to use a special connector for 3 pipes (cyl. 2, 3 and 4) to fit into the PCV opening in the block. And the vacuumpipe of the carb for cyl. 1 goes to the distributor but the GP1 distributor is a special one as it has/had a big vacuum-canister.
Nowadays most people fit a hose from the PCV opening to a breather tank and do not connect vacuumhoses to the the distributor as the vacuumsignal is to low for proper working of the advance mechanism.
Thanks for that miniliteman was going to use electronic distributor what is the best way for me thanks.
I would use a non-vacuum electronic distributor if possible with an advance curve suited to twin carbs and the cam used plus a breather system like this:
https://www.burtonpower.com/tuning-g...er-system.html
