Results 1 to 11 of 11
Thread: Which Dry Sump
    Sep 2021
    sevenoaks
    Which Dry Sump
    Has anyone successfully fitted a Duratec engine, with an off the shelf Dry Sump, into a Mk1 Escort, if so which make/model?
    They are all quite pricey, so want to make sure I buy the right one.
    Many thanks
    David
    Oct 2013
    Suffolk
    47
    194
    Re: Which Dry Sump
    Hi
    I make the Opi kits
    And when I build them they are
    Fitted to a block and a wrc crossmember
    Is trial fitted to make sure everything
    Is good
    There is one bolt that is close if I remember
    Correctly
    But never had any fitment complaints
    In the time That I have been making these kits
    That said a Drysump of any description
    Is a aftermarket mod”
    So there is normally a chassis mod of some sort around the corner
    Sep 2021
    sevenoaks
    Re: Which Dry Sump
    Thx, will be in touch soon. Is that a standard wrc crossmember or the one with the lowered steering rack?
    Oct 2013
    Suffolk
    47
    194
    Re: Which Dry Sump
    Not sure mate
    Re: Which Dry Sump
    Re: Which Dry Sump
    That dry-sump system has been 100% reliable, the only issue I ever had was the alternator coming loose and taking the dry-sump belt off the crank pulley.
    Sep 2021
    sevenoaks
    Re: Which Dry Sump
    Thanks All
    I just need to get my head around paying £1800 for a sump, for an engine that costs half that?!
    Re: Which Dry Sump
    Quote Originally Posted by Davemk1trackcar View Post
    Thanks All
    If you end up spending a lot on tuning the Duratec its money well spent
    Re: Which Dry Sump
    Thanks All
    Sep 2021
    sevenoaks
    Re: Which Dry Sump
    Is this the Raceline one on Gordon's?
    Dec 2019
    Rotherham
    12
    Re: Which Dry Sump
    I like the idea of the Raceline dry sump with the pump mounted up inside the sump. According to their website they are not for RWD setups?
