Results 1 to 7 of 7
Thread: south african escort brakes
    I support TS Decade Plus User
    alladdin's Avatar
    58
    9,966
    154
    anyone have info on rear drums that are larger dia than uk RS ? look to be 9 1/8 inch ish ? shoes are still 2" wide. fitted to one of the export axles ( 50p shape diff cover). all in good condition so if spares available in future i will keep the brakes. ( shoes girling) , thicker on bolting face than uk drums.
    any help welcome.
    3,003
    Re: south african escort brakes
    I thought 9" was the largest std fixture - maybe the drums have been skimmed - a 1/16" depth of cut isn't beyond possibility to correct an oval or grooved / scored drum?
    alladdin's Avatar
    58
    9,966
    154
    i suppose you could be correct but they all look new tbh its about 5mm bigger. they are a different "style" to uk drums in that they are less "sculptured" if that makes sense , just plain machined out drum - no shape to faces.
    Tyre Kicker briang's Avatar
    Jun 2018
    chesterfield
    28
    Do they look like this? These are the rear brakes from a Mk1 Mexico.
    Brian.
    Click image for larger version Name:	mexico solid drum a.jpg Views:	36 Size:	88.5 KB ID:	87526
    alladdin's Avatar
    58
    9,966
    154
    yes i think the drums do at least, didnt take much notice of the backplates. im not sure they would bore out 5mm tho ? and are the face plates at least 3mm thick rather than the 2 mm max on mk2 ones ? cheers
    Jun 2018
    chesterfield
    28
    Face plates? If you mean the thickness of the drum where it mounts against the halfshaft flange then it's just under 7mm.
    alladdin's Avatar
    58
    9,966
    154
    Quote Originally Posted by briang View Post
    yes thats what i was refering to. it all adds up but a 5mm or so skim out still seems a lot. i will get pics next time i look but they may well be as yours.
