Mk2 escort parts road and rally
Below is only example of some.
Located in Ireland but deliver properly packed and tracked. PayPal accepted.
For more info or extra pics pm here or preferably call or for pics what's app 00353 87 4152081
Pair of Ap 2383 historic Grp4 2 pot calipers. All bleed screws removed and caliper threads checked perfect. Pair 500 pound
Pair of twin 40 dellorto dhla carbs with throttle linkage. Good condition matching pair from proper 145 bhp rally xflow engine. On shelf 6 year only need clean. Note
1 banjo and 1 banjo bolt missing. 2 dust covers missing. Pair 320 pound inc linkage.
Pair bilstein 2.8 capri suspension struts with inserts. Springs , top caps and top mounts pair 350 pound
Also same but proper grp1 bilstein struts cw inserts and gaitors , no springs or tops. 330 pound
3j driveline nxg English 22 spline lsd with side bearings, very little use.
530 pound
Gen ford 4.4 english cwp. As new 220 pound
Gen ford full 4.4 diff excellent 250 pound
(Note detail pics can be sent for diffs etc)
Gen ford full 4.1 diff 180 pound
Lotus twincam steel flywheel 6 kg. As new. Allows 215 mm large clurch disc and suits xflow also 150 pound
Selection of mk2 escort genuine ford track control arms. Good 2nd hand. 50
Pinto steel skeleton flywheel and Sachs cover and disc to suit 100 and 200
Selection of distributers ftom 20
Mk2 rhd steel dash suit lhd to rhd conversion 90pound
Rs2000 steering wheel 250 pound
Rs2000 rear bumper perfect straight . cw side pieces 200
Rs2000 custom centre console 220
Pair rs2000 alloy engine mounts 90
Complete steering colume 60
Std mk2 pedal box 50
Wiper motors 30 pound
Lots of door parts
Mk1 escort half cage . Safety devices 170 pound
Excellent sierra cosworth rwd t5 gearbox cw ancillaries 1500 pound
Mk1 escort 6 dial dash clocks 110 mph 250 pound
Few weber 32 / 36 carbs 90 pound each
Also 1600 sport snd rs2000 inlet manifolds
Mk1 escort mexico, lotus twincam, rs1600 pedal box c/w cylinders. Rare gen ford. 400 pound
Crossflow dry sump kit
As new
Titan oil pump, alloy rocker cover. Steel simp pan. Mocal remote oil filter mount. Lot 500 pound
Rare genuine MASS racing crossflow exhaust manifold. Utimate . Not copy. No dents. No repairs. No cracks. 350 pound
Also new stainless xflow 4 branch exhaust manifold 350 pound
Lots of std , fast road and rally 1600 xflow parts available. 711m blocks, crankshafts, con rods etc
Kent a8 xflow cam and matching followers numbered no wear 90 pound
Same but ford gt , 1600 sport ghia etc
Ford bm4 cam and matching followers numbered. No wear 90 pound
Lots of other mk2 escort parts. Road, race, rally. Xflow. pinto .english axles, atlas axles .
Most standard small bits and pieces
Genuine secursiv 2 dr 7 piece set of very clean glass.
Enquiries welcome.
