Im struggling to setup my Mk2 escort steering column. It had a mk1 column fitted and usable, but in an attempt to get the stalks and standard stalk surround fitted, as well as a mk2 rs 2000 wheel, i changed the column to a mk2 early short 967mm column. Then the column UJ was too short, so i bought a long gp4 UJ, the column is still 10mm too short. I have another spare column which is the same length.
i have spent ages reading up on the forum, and i think it should all fit, but doesn’t. The answer could be a later mk2 1000mm column but i cant find one at present, either locally or on ebay etc.
i think my two choices are either to swap back to the mk1 column, or perhaps buy a new RIX column. I am advised they are 1000mm has anyone fitted one, and can you fit the stalk shroud. I dont need to use the steering lock or standard switch. Motorsport tools will take back the unused group 4 uj so thats £50 back off it.
it seems much simpler building mk1s as they are all the same. I don’t have much experience with mk2s
