Results 1 to 5 of 5
Thread: Electric line-lock solenoid for brakes
    Mechanic beeRS's Avatar
    Apr 2007
    Chelmsford
    721
    90
    Hello all,
    I see a lot of builds on here with lever type brake line-locks fitted, but has any tried using an electric solenoid type? I was thinking of this one...
    www.mattlewisracing.co.uk/product.php/2496/1228
    It'd be interesting to hear peoples thoughts on this.
    Mechanic runoutofrigos's Avatar
    Aug 2006
    North London
    724
    Re: Electric line-lock solenoid for brakes
    We used a very similar device on a drag car years ago, worked perfectly. It was wired to a button on the steering wheel, so once in the blocks and the brakes applied, the button was pushed, and a burnout followed every time
    They seem to be a lot cheaper now than they were in the 80s though, thanks (probably) to the Chinese.
    Simon
  3. The Following User Says Thank You to runoutofrigos For This Useful Post:
    Apr 2007
    Chelmsford
    721
    90
    Quote Originally Posted by runoutofrigos View Post
    Simon
    I was thinking of fitting this way, but maybe a switch on the gear lever, or close by.
    Another question; if the solenoid were ever to fail on one of these, would you be left with brakes that are jammed on, or brakes that stop working?
  5. #4
    Aug 2006
    North London
    724
    Well, I don't know about the particular device you have chosen, but ours was definitely "fail-safe". It works as a through joint until the solenoid is powered, which then blocks the line. This is why the brakes need to be applied before powering the solenoid, as it holds the pressure to the calipers. As soon as the power is killed, the pressure is released, just like taking your foot off the pedal.
    Simon
  6. The Following User Says Thank You to runoutofrigos For This Useful Post:
  7. #5
    May 2004
    Norn Iron
    1,025
    Simon
    Yep, very common and safe. Used it on mine for years.
    There are a few different styles of solenoid that look a little nicer if that matters to you.
    Only one negative with some, is they do not directly take typical brake pipe fittings, and there can be adapters to screw in first. Americans must use odd pipe threads for a lot of stuff, but adapters are usually supplied where necessary
    Mine is the TCI brand
    https://www.summitracing.com/search/...kr=line%20lock
    Many years ago I actually had a little key operated unit with a one way valve in it. Plumbed into front brakes for a security device. With the key "on", when the brakes were applied...they would not release. A neat theft prevention device, but it never really took off.
    Turn the key "off" and brakes released and back to normal
  8. The Following User Says Thank You to stevieturbo For This Useful Post:
