Results 1 to 5 of 5
Thread: poly windscreen mk2 escort
    May 2014
    surrey
    126
    any one know company for poly windowscreen for mk2 escort
    4,875
    Re: poly windscreen mk2 escort
    As far as I know the front windscreen needs to be glass because of safety.
    May 2014
    surrey
    126
    need one for drag car
    Bodger Caprimaniac's Avatar
    Jan 2011
    Norway
    OK. Buy sheet of clear plastic, polycarbonate, 3-4mm. Take your old windscreeen off. Place the plastic sheet over your windscreen. Push down on the edges; maybe use some heat for easier bending. Mark with a pen, cut with a jigsaw. I used fine teeth blade. No melting, easy cut.
    Depending on how you'll fasten your plastic screen; nuts'n bolrts, or rubber; adjust the size of the windscreen ccordingly.
    I did it to my MK2 Capri Drag car, no issues.
    TURBOSPORT SPONSOR Turbosport Sponsor TJM's Avatar
    Jul 2004
    Bridgend, Vale Of Glamorgan
    644
    You could try Plastics 4 Performance as they make thermoformed ones.
    TJ Motorsport
    45 Allt Dderw
    Broadlands
    Bridgend
    CF31 5BZ
    http://www.tjmotorsport.co.uk
    Follow Me On Facebook
