Results 1 to 14 of 14
Thread: Quaife 60g
    Jul 2017
    Lourdes
    Quaife 60g
    Hello, I am in France and I am rallying in a category that requires me to keep the original structure of the vehicle. I would like to install a 60g quaife in An escort mk2 rs2000 with With std tunnel...
    Jul 2017
    Lourdes
    Re: Quaife 60g
    Have any of you already installed this gearbox without changing the tunnel?
    Mar 2008
    west bromwich
    1,861
    Re: Quaife 60g
    It want fit with a standard tunnel 60g is the heavy duty one , think elite do one that's strong and will fit , quafie do one the same a a t9
    Re: Quaife 60g
    Quote Originally Posted by xpackboy View Post
    According to Quaife’s blurb the 60g is a direct replacement for a T9 but to me the dimensions look larger especially it’s depth which will result in the bottom of the gearbox casing hanging down under the Car. If you take a look on Motorsport Tools Website there are dimensions of the Gearbox.
    I have no experience of fitting this gearbox into an Escort but back in the mid 90’s we fitted its Heavy duty brother and that did need the tunnel lifting up so the box didn’t hang down and drag on the Forest tracks.
    Mar 2008
    west bromwich
    1,861
    Re: Quaife 60g
    You won't get the g60 it's too big , I got a t5 cosy box in standard tunnel used a bottle jack just to gently make clearance, iam sure elite do one that's based on a standard box
    Spanner Monkey Mkdu's Avatar
    Oct 2009
    417
    14
    Re: Quaife 60g
    the 60G fit into standard tunnel, at least width if enough if you remove the genuine supports, I did it.
    But I needed to raise up the tunnel at last part, around gear lever.
    It's a pain to get the box out, honestly, that's why I fitted a large tunnel 2 years after....
    It helps to remove box without unbolting the engine mounts and moving all down to be able to remove the gearbox.
    2,659
    268
    Re: Quaife 60g
    Is it not feasible to fit an Auto tunnel?
    Although maybe not be standard fitment in your car, unless it was an auto shell to begin with, it is at least a factory fitment item.
    Feb 2011
    ireland
    1,019
    241
    Re: Quaife 60g
    I fitted many a 60g
    Back of tunnell needs decent rise to get back of box up to correct height
    Oct 2009
    417
    14
    Re: Quaife 60g
    Click image for larger version Name:	Screenshot_1.jpg Views:	39 Size:	92.4 KB ID:	88020
    indeed, it needs room around tail comparing to a rocket one
    the top on the box stay high at the rear also, that's why cutting is needed
    Mar 2008
    west bromwich
    1,861
    Mar 2008
    west bromwich
    1,861
    Re: Quaife 60g
    My elite evo 2 sequential was half the size and as strong 500bhp cossy in a mk2 no problem alt all
    Re: Quaife 60g
    It’s either my poor eye sight or that Elite gearbox looks taller than the 60g from the centreline of the mainshaft. They are a nice gearbox all the same.
    Mar 2008
    west bromwich
    1,861
    Re: Quaife 60g
    It does look like in the pic, but fitted sweet
    Mar 2008
    west bromwich
    1,861
    Re: Quaife 60g
    Wife wasn't impressed when it was in the bedroom to keep it safe lol
  15. The Following User Says Thank You to xpackboy For This Useful Post:
