Is there anyone out there that has got full vvt working with a DTAS60 ecu?
I have the engine running, but it does not read the cam position.
When using the oscilloscope function I can see the ECU gets 5 pulses from the sensor in 2 crankshaft rotations.
I have selected flywheel mode 13 - ST170 36-1 / 5 tooth cam wheel.
Does anyone have an idea what could cause the DTA to not process the pulses to a cam position value?
(cam sensor noise filter is deselected in sequential injection menu)
The ECU is on firmware 41.00
