Just a quick one will I need new shims when changing the cam to a bigger one? or will i get away with the existing shims?
maybe, its all depends on how accurately ground the base circles of the cams are
you might be able to mix and match with what you have. The set of 16V cams I did last required about 10 to 12 thinner shims to be installed. I had a friend supply a good choice of thinner shims or else I was going to just surface grind a pile of them.
Custom 4AGE 20V conversion parts:
S-86.com
I was told that the std ones are usually fatter than required, so If you have a file as wide as the shim, you can rub it on the file and take some off it to get the right size.
File them down on the underside, don't see the problem... As long as you keep them flat on the file.
shims are hard, a file will take weeks to thin them and the chances of keeping the faces parallel are slim, they need to be surface ground
