Hello.
I installed a new CWP- set this winter and have been testing it in the streets 3-4 times this spring. First time I experienced a loud whine at 60 mph. It's a little more quiet now, but still some whining: Both on- and off throttle.
Anyway- after getting the oil out, I have inspected things closer. First off, the lash felt a little tight with a warm diff. I will check it again after it cools.
This is a Rally Design 3.44 CWP set, BTW.
What I really would like input on is the wear pattern. I think it looks quite OK; maybe a bit much on the heel- side. But mostly centered at both sides.
Never "blued" the pattern at setup; put in the stock Ford shim and its felt OK, so.... Do I need to take it apart and shim it more in or out?
Attachment 88483Attachment 88482Attachment 88481
