Does anyone know if the shoes/ cylinders/ drums are the same as the uk 9 inch ones?
thanks
Dan
thanks
Dan
Yes
Ive just converted my axle to an english and kept the 9" brakes off the Borg axle.
I got mk2 Rs 2000 cylinders and there exactly the same.
Capri 3l shoes also the same.
3lts capri shoes are wider than uk RS shoes
swapping to the 3 ltr drums and shoes was popular upgrade in day which i used myself. they are actually too good as
you need a bias valve to reduce the rear effort - i used a modified mini rear limiter as was common back then.
They are - the man said WIDER not DIAMETER
