Hi All,
I'm running a 205 Pinto in my mk2 Escort.
It's been fully rebuilt and bored to +0.5mm pistons.
Other than that it is completely stock.
I've swapped the set advance electronic distributor for one with vacuum advance and separate module.
Timing was set using the guide on the forum.
I'm using the 30/34 DFTH carb that came with it as stock (a 32/36 is to replace it in the future if I can find one).
I've converted the carb to manual choke, and replaced the idle control motor with a bracket and end-stop bolt.
While I've been running in the engine, I've noticed it doesn't seem to fuel right.
I have adjusted the mixture screw a few times in hope of finding the golden spot, but no succes.
Sometimes I get a little burst of acceleration when letting go of the throttle, sometimes it holds back a bit etc.
Sometimes pulling the choke helps acceleration, while at other times it reduces power.
I've pulled the jets to see if I had any blocked ones, and found that they do not match the factory specs for my carb (85HFDA)
(My carb/engine used to be an automatic, currently fitted with a T9)
My jets are:
Both idle jets are a bit bigger, but the secondary main jet is smaller with a bigger air corrector.
Could this cause it to run lean once the secondary opens up?
I haven't found anyone selling these jets around here, so figured I'd ask here first before I'm going to order internationally.
