Results 1 to 15 of 15
Thread: Crossflow on Jenveys
    East Sussex
    58
    5,023
    Linered AX block 85.9mm JE Carillo pistons (1799cc), 11.5:1 CR, Flat head ported to Seahaven motorsport spec with Rec valves, Seahaven motorsport cam,steel crank and rods. 45 Jenveys with full MBE management, graph is from the 1st mapping session when it was all brand new so there's more to come with further mapping.
    [img]http://media2.turbosport.co.uk/2011/5/2012052723064105755151.jpg[/img
    East Sussex
    58
    5,023
    Re: Crossflow on Jenveys
    Nov 2003
    Wirral UK
    6,740
    257
    Very impressive indeed!
    http://escort.accelerator.org
    Racer Decade Plus User sambo's Avatar
    Oct 2005
    Bexhill on sea
    1,934
    107
    Looks lovely Nick! Phwoooaarr!!
    Great power and torque too!
    Spanner Monkey FrEdOoOo's Avatar
    Mar 2009
    Portugal
    384
    25
    Very Impressive Nick
    May 2007
    762
    Great results, when do we finally see 200 HP crossflows ?
    i doubt we ever will, without running on some exotic fuel,
    lets face it they couldnt do when hot rods ran x/flows with unlimited mods,
    at the end of the day an x/flow head can only flow so much air which pretty much caps the power ceiling, if your limited by airflow then to a certain extent you can compensate by revving to hell, but to make an engine work at 10,000+rpm you need a nice combustion chamber something an x/flow doesnt have, sure you can chamber them but that spoils the inlet port and introduces valve shrouding, so your back to hurting flow and thus lowering power possible
    3,641
    And a big fat spark.
    Jan 2008
    Up the garage
    2,775
    218
    Quote Originally Posted by Pushrod King View Post
    Very nice - bet that sounds mean!
    Is that the AX block you had for sale recently?
    East Sussex
    58
    5,023
    Quote Originally Posted by HonkyWhiteTrash View Post
    Thanks,no I've still got the other AX block (along with 2 complete 711m engines,2 bare blocks and an early Mexico 691 block).
    Ireland
    3,579
    173
    Nice engine, I would have thought an alloy head would be the best option, 180bhp from a xflow is very good
    I think 200bhp would be possible, as Graham said its all about the head flow, a downdraft alloy head and something similar to a 2.0 bdg bottom end would surely make it, just about, the biggest limitations I see after that are cam profiles, being flat follower pushrod, and the combustion chamber shape
    East Sussex
    58
    5,023
    The worst thing with the cam profiles is the fact that you can't get enough meat on the cam to get a decent grind and profile as it wouldn't fit through the cam bearing bores, also with the current setup the followers are only just far enough into the bores to not fall out when at zero lift! Ideally the followers need to be over 10mm longer which would then also mean having shorter pushrods made.
    Oct 2008
    italy
    471
    21
    so a q came to my mind;
    are those higher lift rockers really worth the cost?
    well if you need more lift and cant get it from the cam then high lift rockers are the only possibility
    May 2007
    762
    John Wilcox makes a 2200 cc crossflow, 200 BHP could be close to possible ?
